PC Liquid Cooling
alifffresto
anyway now u all recommend what top for d5 ah? ek x-top already eol and the revo is quite fugly imo.
alifffresto
You want combo or no want combo? Barrow one not bad... If not alphacool?
Sent from Huawei NEXUS 6P using GAGT
At first wanna use the aqualis d5 but then xtremerigs give quite bad review. So i intend to use the barrow yph65 reservoir, like bitspower tank z and ek-xtop... check ek website already eol...
Now thinking of alphacool eisdecke to pair with res but can't seem to find any review...
monikernemo
What reviews pump top can have hahaha build quality?
I think sometimes boils down to functionality bah (I.e. where the ports are placed LOL)
My only gripe with the barrow combo is the top ports being too close; you can only put one fitting on to one of the ports. If you intend to use one port for water coming into reservoir/pump, you can't even close the other ports using a proper plug.
For myself I use the blue alphacool rubber plug found in their radiators to close lorh LOL.
shadow84
Sign up or performance pc newsletter. They may issue 8-10% discount during holidys. Iirc, they isued a 10% during christmas.
kendallkoh
Eh. Anyone know if PETG tubing is supposed to slide out so easily with the compression fittings (for hard tubing) ah.
