PC no response after pressing power button
omelet
So I got this problem starting few days ago.
When I press power button, there is no response from my PC. No light or any fan spinning. However, if I waited long enough, it will suddenly turn on by itself after 5+ min?
Once it is turned on, everything works as per normal.
This issue will reoccur again after I shutdown the PC and waited around more than 30min and try to turn on again. If I turn on again immediately after shutdown, it will turn on without issue.
I tried different power socket, doesn't seem to be the socket issue.
Is my PSU dying?
Spec:
MSI Z370 Gaming Pro Carbon
i7 8700K
16GB 3466 Ram
1TB 760P
2x 4TB WD Blue
MSI RTX2070 Gaming Z
Seasonic Prime Platinum 650W
jt2901
It looks like a PSU problem from what you have described.
Got a spare PSU to test?
Else, unseat everything first, and just see if the PSU can power up the board only.
jtjt00
TS, I am using the same PSU in one of my rig -->
Do update here once resolved.
Mythmaker
I used to have this problem. It turned out to be a motherboard issue.
omelet
I do have a spare Seasonic Gold 500w, but it has been in storage since forever... not sure if it will have any issue...
Now I also kinda regret making this built RGB...:sad:
Huh? You have this issue?
my guess its a PSU issue.
This reminds me, my previous PC, i5 2500 with Gigabyte board had a similar issue...hmm..
jtjt00
No .........................
omelet
So after testing with a spare PSU....the issue persist...:eek::eek:
Oh well...looks like it is motherboard...:sad::sad:
hafiz116
Are you sure your spare PSU is good? You did say its been "in storage forever". I would try n see if a friend can help to help you test to double confirm before going for a motherboard RMA.
Outramkia
My 2 month x570 mobo was the same. Went to service center, confirmed dead by the tech. Replaced with another one.
