PC problem
croc1977
My desktop as seen on the right got some issue..
i went to update the bios but somehow it hang halfway .
force reboot . jialat. pc boot up 3 sec shut down by itself.
tried remove hdd , vga card all same.
tried remove cmos battery same . want to reset bios jumper but there is no 'jumper' for me to plug in?
MSI Global ? Motherboard - Z77A-G43
any advice? don't think is psu cos got power i believe is bios corrupted liao. anyway to recover?
msi is corrbell rite? must remove mb or can pass them whole sys? and check?
killless
Must remove mb. They don't take ur whole set. Want bring to technician try see if they can fix 1st?
croc1977
Maybe I drop by pc themes tomolo
If board really bye need rma
Then I buy board on the spot then grade with i7
Any idea what time they open tomolo
