Pc seems dead anyone can help
wtfwfs
Hi there
Today just wanted to switch my pc on
But it went into a page to ask me to select boot drive and seems
Like can’t read my ssd or hdd
I’ve installed os at ssd
Any help?
croc1977
Hi there
Any help?
SSD what model? how long le?
when i s last time you on pc ? what did you do before?
Koenig168
Are you able to see the SSD and HDD in BIOS?
If so, probably the boot manager is corrupted. You can restore from backup (if you have a backup :) ) or reinstall Windows.
There are some utilities around the web which claim to be able to repair the boot manager. You can google for it.
wtfwfs
unable to see the SSD and HDD in Bios
ZrE0_Cha0s
Try switching to other sata port and cables see. If really still nothing most likely either your drive or mobo is GG.
wtfwfs
so even now just plugging in SSD only
its shows a black screen with
"PXE-M0F: exiting intel boot agent
reboot and select proper boot device or insert boot media in selected boot device and press a key_
wtfwfs
an uodate!!!
apparently my sata ports were all disabled?
what may have caused it...
reseted my OC for it -.-
wtfwfs
anw would this be worth an upgrade or is already junk?
cpu: intel core i7 4770k @ 3.5ghz
haswell 22nm technology
ram: 8gb dua channel ddr3 @ 666mhz 9-9-9-24
mobo: asrock h97m Pro$
gpu: 2047 nvidia geforce gtx 1060 6gb (gigabyte
Koenig168
an uodate!!!
Go to BIOS and select "Default" settings. This should restore your SATA ports.
singupingu
You pc still very relevant. If motherboard got issue, try get a 2nd hand Z87 or Z97 board. You can do OC on cpu too with the z series.
Asrock board pretty often have issue when it age. From your problem, look like board caput
Sent from OnePlus ONEPLUS A3003 using GAGT
croc1977
yeah...mayb if come back again.. means m/b going soon
joshuaho
The 8gb of ram at 666mhz quite eyesore :eek: Can consider changing to 16gb 1600mhz since ddr3 rams aren’t as pricey as ddr4
singupingu
It's a 1333mhz I believe. 666mhz in dual channel should be 1333mhz
Never seen ddr3 at 666mhz before.
wtfwfs
THANK YOU FOR ALL YOUR INPUTS
ive rebooted the pc and installed win7 instead of 10
hope everything goes well,
currently still on AIO and mainly aircooling
dk should i SLI or do any upgrades to the system,
but ill like to overclock it...
now its doing 4.0 ghz at about 75-85degs
