pc system from tradepac
Jody2205
hi folks
im getting a pre build pc package from tradepac and i am wondering if they would charge me for assembly.
will they give further discount if i bargain given that it is a package price?
another question is do they have a disc or usb drive to help install os if i only have the key bought from reddit?
thanks
jtjt00
You can't expect good service from Tradepac. It is a buy and forget shop. You need Fortan instead.
spiky0180
Why not consider DIY? If you buy pre-built from tradepac, I don't think they will troubleshoot for you if you encounter problems later.
Maybe list down your needs here and the guys here can suggest a build specific to your needs?
ykgoh
hi folks
thanks
Assembly is already included if you buy a complete set. How TradePac defines what a complete set is you better check. Think minimum must include:
  1. Casing
  2. PSU
  3. CPU
  4. Motherboard
  5. RAM
  6. HDD/SSD
  7. Optical Disc Drive (maybe)
  8. Keyboard/Mouse (maybe)
If you buy your OS separately from Reddit, don't think the shop will bother installing for you out of goodwill. They just assemble the hardware, then boot into BIOS show you it is working fine (CPU, RAM, SSD, HDD all detected and correct).
OS you have to go home put onto a bootable flash drive and install yourself.
You get what you pay for.
Phen8210
hi folks
thanks
Please don't buy a PRE-build package, it's not worth it and it's also not PRE-BUILD. When u buy then they will gather all the parts and assemble together.
The so call "PRE-BUILD" package usually have those part they want to get rid off, which is usually not ideal. Instead, start another thread then state your budget and needs, we recommend you the better parts. Then, you can bring the list of parts you want to buy and have them assemble for you.
Krabs.
those "recommended" parts list by shop are bad ..... they skimp the budget on casing , power supply , graphic card ....
then pump towards i7 cpu to make it appeal to buyers because they easier to remember "i5 good i7 best"
gaming most important is graphic card ...
but it doesn't benefit the shop or Branded pc as much to pump another $200 higher into the graphic card budget ...
the customer don't appreciate the small number difference like 1050 vs 1060 .... the difference looks small because "only 10"
while they see i7 will feel very attracted
Hongjia84
Thanks all for the feedback
Sorry to use this account to reply coz i dont know why i couldnt log in with my phone
I want to build a pc primarily to game dota2 and csgo at medium to high settings
After running through this forum i somehow think the following suit me given my tight 1k budget which inclusive of mornitor and OS
i5 6500 + asus h110m-a d4 mother board
Zotac gtx 1050 ti 4gb
Any 8gb ddr4 ram
Any 1tb hard drive
Any 24x optical drive
Any case and psu
Dell se2417hg mornitor
So i thought i could buy a gtx 1050 to add into the cheapest asus i5 6500 package at $592
jtjt00
You should get an SSD for OS + apps. HDD is for storage. Don't let the HDD lag your rig.
Steyr69
You might like to reconsider the Any Case n PSU.
Should get a good PSU also.
This is the engine of your rig.
Even more important since for gaming.
Ram.....get branded ones like kingston (lifetime warranty)
Sent from Asus ME173X using GAGT
MianBaoFren
direftw
Any 8gb ddr4 ram
Any 1tb hard drive
Any case and psu
If just dota 2 and csgo at medium to high settings, even a i3 or an older generation graphics card can do.
Hongjia84
Appreciate all advice and feedback
I have made up my mind to the following
I5 6500 + msi b150 bazooka -- 439
(This mb to get free msi mouse)
Zotac gtx 1050 ti 4gb -- 209 (qoo -20)
Kingston 8gb ddr4 -- 72
Samsung evo750 120gb ssd -- 59 (qoo -10)
Wd blue 1 tb -- 72
Asus 24x dvd -- 25
Techware f3 case -- 49
Fsp 450w -- 58
Wins 10 -- 27 (lazada)
Dell s2417hg -- 159
Total $1169
Not too sure if 450w is enough because i will be getting a printer sometime soon.sorry i know nuts about power consumption
Any review on Infinity computer?
MianBaoFren
Wd blue 1 tb -- 72
Asus 24x dvd -- 25
Fsp 450w -- 58
Dell s2417hg -- 159
Total $1169
450 enough. but if I am u I delay buying my pc. Next month new gen cpu.
Sent from A Cat Who Does Not Need A Reason To Post using GAGT
-Synchronicity-
Emm printers shouldn't draw power from pc at all...they do provide power plugs for a reason after all. Unless you plan on buying portable printers like canon selpy series
DrSheldonCooper
For me I went to PC Themes at SLS. Prices are fair but service imho much better than tradepac. Bought 2 PCs from them this year. Tiagong from the laojiaos here that tradepac is one of those places where you know what you're doing or you already research properly the prices before heading down.
One downside is PCThemes don't help you install the OS if you don't buy from them. I bought mine online also. Think they got some contract with Microsoft. But when they build for you they will let you test ma. So just ask them how to install from the bios and they will guide you, but you have to do it yourself. It's not too difficult anyway. I'm quite the computer idiot and still managed to do it without much difficulty.
Btw can try Lazada also. That time when I was buying, everyday got a different credit card promo. Don't know nowadays still have or not. Like weekends it was DBS/POSB. Additional 12% discount or something.
And might I suggest you get at least a 250GB SSD? I'm currently using the 250GB and am wishing I'd shelled out a little more for the 500GB actually. Still usable though.
Btw I'm not any computer pro or anything. Just sharing my buying experience earlier this year after doing some research here on hwz. :)
Shahmatt
Do you need a DVD drive?
For your gaming needs even i3-6100 is enough I think.
Ginzilla
I had a really pleasant experience at Infinity Computer.
Can look for WenXie.
He quite steady, honest and sincere.
Wd blue 1 tb -- 72
Asus 24x dvd -- 25
Fsp 450w -- 58
Dell s2417hg -- 159
Total $1169
Shahmatt
Consider a mobo with m.2 PCIe port so that you can buy a PCIe based SSD later. Speeds are much faster.
