PC won't boot POST, HDD light not blinking
Swiftyz
Hi Guys,
This is a continuation or an evolution from my previous thread.
http://forums.hardwarezone.com.sg/hardware-clinic-2/windows-10-bsod-5349649.html
So I bought a new crucial value ram, 8GB 1600Mhz DDR3. Insert in, power it up, nothing happen. Turn off and on, managed to get it started finally. So I switched it off thinking everything's fix, gonna fix back up everything, GPU, monitor, etc.
So to my horror, turn it on again, monitor will not on at all, HDD light will not light up after a few blinks. All the fans are spinning, power led is on.
I really don't know whats the problem. Please advise me if you can.. Thanks!
ZrE0_Cha0s
seems like its either PSU or mb issues...can ask if u use ur old and test?
jtjt00
you add Crucial 8GB stick to Sharetronic DDR3 4GB?
Swiftyz
I have no spare mb or psu le. All sold.
Nope, i took out the Sharetronic DDR3 4GB, replaced that with the Crucial 8GB DDR3. My bad, wasn't clear there.
ZrE0_Cha0s
sorry i wasn't clear either :p
i mean use back ur old ram and see if BSOD still there or not.
was using my phone :p
