Pc wont start, change motherboard also same
KillerBee
Wondering if i so sway killed 2 motherboards :s22:
Old motherboard was working fine but suddenly cannot on. Changed new board, can switch on once only then it auto off. Now cannot on again. Any idea what could be wrong?
Psu, cpu, ram, gfx card all bought less than a year ago
Previous board z87, new board z97 but both asrock
KeYoKe
provide full specs of the parts of the rig:
1. Processor
2. PSU
3. RAM
4. GPU
5. Storage drive/optical drive
shadow84
U cfm u plug all cables correctly? Try w/o gpu and use your OS disk nia, be it ssd or hdd. If u have both, den plug in the ssd nia, and not the hdd yet.
See if can boot up or not.
KillerBee
1. Processor
2. PSU
3. RAM
4. GPU
1. I5
2. Seasonic m12 620w
3. Corsair vengeance 2x4gb
4. Palit gtx660
5. No optical drive, samsung ssd for windows + few hdds for storage
KillerBee
Tried without gpu, same
Gonna try unplug everything & redo
KillerBee
Try with just ssd plug in.
Solved!
Tried my luck plugging in the power plug into the wall outlet directly & it starts! :s11:
Plug back into the extension block, doesnt start. Unplug my powerline then it starts. Funny leh, maybe the powerline is the faulty thing all this while. I do remember previous motherboard started showing usb power surge warning before it wont start at all
blue00
where u stay?
if near me i help u take a look... :)
shadow84
Solved!
Throw away your extension plug liao... potential hazard for other devices.
