PCI-e Wireless LAN suddenly not detected
tony_ong
Hi,
I like to check what can cause the pci-e wireless LAN card to suddenly not got detected?
I using the comp halfway suddenly disconnected and i go into network and sharing center and check the adapter it is not there anymore.
Thanks.
jtjt00
Shutdown and remove the card and clean the gold connector edges. Plug in back and secure with screw and see how.
ykgoh
last time I also kena with my tp-link PCI card. Unplugged and re plugged it in, then OK Liao.
But happened twice within 3 months. Soon after the mobo also up lorry and fails to power up to BIOS.
Could be mobo failing soon also.
tony_ong
Wa sian if mobo up lorry think hard to find h77 boards liao now?
localITguy
Suspended
ha. lga1155:(
mine just uplorry. know you you feel. if really uplorry:(:(
try using at other PC and see if it works ..
could be card uplorry but hard to say
