PCI Mounted Fan Cooler
brightside
Where can I find this in SLS?
Do enlighten me, thanks!
brightside
First you need let us know whats the part name? its just two fans lying down.
Erm its stated in the title.
Basically I need the red brackets. Its a fan bracket that lets you utilize the PCI mount on your mobo so that you can blow air at the GPU.
idjekyll
Based on my exhaustive search up and down SLS, all shops only sell those normal case fans of different sizes. You can try Chamoxa but if they don't have then noone there has it. Trust me, my tired legs can attest to that.
ahwei91
Used to see such thing in several SLS shops last time such as uvnium(but closed down alrdy).....
brightside
Wow you were also looking for this or something else? Thanks for this. I'll be sure to check out chamoxa!
Alphas
pretty useless, it cannot allow the cool air from outside to circulate inside.
brightside
Hmm, then what would you recommend to cool the gpu? I have two years warranty left for my gpu. Don't want to open up and void warranty.
Alphas
you can mount the fan on the side panel to bring cool air in, if the casing does not have one, then you should cut one for a 120-140mm fan.
idjekyll
other than having a case which actually positions the gpu near intakes, i dont think you can have dedicated gpu cooling besides water cooling.
monikernemo
Why need so much cooling... At most get those case with side panel fan mounts.
idjekyll
also, it's only good for the gpu if the fans blow fresh air from the bottom of the case to the gpu. if it's just blowing air from the case itself then i think minimal to zero difference.
