pcthemes installed my fan direction wrongly?
multijesture
i just realised my front two fans have stickers facing OUT. is it installed wrongly lol
shadow84
Maybe... just remove the four screws at each end and turn it around.
jtjt00
Not wrong if casing air flow is from rear to front.
it should be push pull config.... cannot be all pull or all push
shadow84
Sticker side indicates air coming out. Perhaps you could tell us all the fans' position and sticker direction??
Krabs.
when install back , use 2 screws can already no need all 4 ........ 2 diagonally
wwenze
Some people prefer their fans to not rattle due to being secured on only a pivoting line instead of a plane.
tmfwy
This is possibly poor workmanship from vendor
Traditional cases air intake from front / Bottom, exit from rear / top
multijesture
yea i have unscrewed and fixed it back correctly. i expected better from pcthemes
Godeau
It might not even be pctheme's fault if the case came factory installed with the fans, that unless u bought extra fans and asked them to fix those up..
