Performance Multi ways extension wall plug
tsteo77
Recommend this high performance/quality multi ways extension wall plug to improve your computer experience.
I'm using such similar but less expensive wall plug. Free to share your opinions.
https://www.amazon.sg/dp/B09MQ2GYBW/ref=syn_sd_onsite_desktop_44?ie=UTF8&psc=1&pd_rd_plhdr=t
keenklee
Deceased
tsteo77
IMHO.
This is in my shopping list.
You're using this or something similar ?
Yes but not as good as this and without usb plugs. My wall socket is 2 sided, so i have 1 on each side and i can plug in a total of 4 items.
Pardon me but no risk of overloading?
The picture on the left indicate that it has all necessary protections and it can withstand a high temperature
of 750 0c. Take care not to exceed the max rated current of 13a 250v of your wall socket.
tsteo77
This one even worse design than the first one you shared. I’m referring to the scenario where there’s 2 sockets side by side. The first one at least won’t block the other socket. The typical cube design will block 1 side.
this one below probably better.
https://amzn.asia/d/4qRgZTO
You did not read the product description properly. It mentioned non blocking design for those who have 2 sided wall socket like mine.
froztheart
Right, then it would mean its not recommended to have this a multi plug connected with this for PC rig I suppose
Gaminator
I'm using a 4-gang APC one (black), I didn't know Schneider did APC though....
tsteo77
This plug is rated at max 13a 250v 3250w. Should be safe for use on standard wall socket unless you want
to use it for items that exceed this limit. Then i afraid even that pretty safety sticker won't save you. :)
86technie
Right, anyways come to think of it, any smart multi/single plugs that have safety marks?
Require 6 to replace mine.
Best go shops like Self-fix, Challenger take a look.
Multi plug there's isn't a good one that I recommend but I won't recommend
one with USB charger.
Electrical extension wise Sound teoh and Daiyo which are local brand are OK.
tigerwoods
Have a few of these, well make quality and affordable
