phantek 350x hot temps need help
nicholascheans
Hi all along i have been getting high gpu temps.. do i need more fans.. i am just using the stock case
ystoh133
How high is high? And in general stock provided fans are not sufficient. You will normally want at least 1 + 2 rear and top exhaust and 2 intakes infront
tsteo77
You might want to use floor fan to blow at your pc with side cover open until you get those cooling fans.
Swiftbladez
How hot is your room, and how many monitors at one time? To even see if it's a casing problem or lack of airflow, you can simply open side panel and test the temps, if really much better temps, then yes can get another fan
vironix
Set a temp limit lor
Sent from the anal hair of Thanos using GAGT
