Phanteks Enthoo Evolv pwm hub
scorpio88
Hi all,
It has been more than 5 years since my last build up of my DIY pc. Yesterday I bought my Phanteks casing with my Asrock z370 pro 4 mobo and Cyorig H7 Heat sink.
I understand the pwn hub with the cpu cable is to be connected to the mobo's cpu_fan.
But where can I connect my Cyorig H7 fan to?. What is the correct way of connecting them? And how to configure pwn in my mobo?
Please advise.
Thank you.
singupingu
The 120mm fan on cryorig H7 is 4pin PWM-controlled as well iirc. No difference from your stock cooler, 4pin as well. The fan on the cooler is to be plugged to cpu_fan header as this header is directly controlled by the temperature of the cpu
For the pwn hub, plugged it to any of the cha_fan header
Sent from Finally Unbanned using GAGT
scorpio88
Hi,
the cpu_fan header is at the mobo?
LLCSG12
Get a 4pin pwn Y splitter.. one end of the Y to H7 and the other end of the Y to the PWN hub cable of Evolve.. and the splitter is plug into the motherboard cpu fan header.
singupingu
Hi,
1. CRYORIG fan -> CPU_FAN at top right corner of mobo
2. PWM hub -> CHA_FAN 1, 2, or 3 (CHA_FAN 1&3 at bottom of mobo, CHA_FAN 2 near the CPU socket.)
LLCSG12
most of the Heatsink fan cable is not long enough to reach the fan hub..
the Case by right should come with a Y splitter but it is not included..
