phone 6 Wifi AC problem
MoyoCase
DOes anyone find the Iphone wifi conenction to 5GHZ AC is limited in range?
i am using a dual band router.
gapboy
i am using Asus router dual band and 5ghz AC do have shorter range than 2.4ghz which is normal.
http://www.speedguide.net/faq/is-5ghz-wireless-better-than-24ghz-340
Disadvantages of 5GHz:
In general, the higher the frequency of a wireless signal, the shorter its range. Thus, 2.4GHz networks cover a substantially larger range than 5GHz wireless networks. In particular, the higher frequency wireless signals of 5GHz networks do not penetrate solid objects nearly as well as 2.4GHz signals, limiting their reach inside buildings with solid walls and floors. R
