Phone cooling method
veltix
Hi guys, Im not sure whether to cool phones be it apple or android. If the phone heats up to 44 degree celcius or above 41. Applying wet wipes on screen and back of phone will cool it faster? Or blowing with fan? Since, I dun have aircon.
Jurong640
Get those blackshark phone cooler. They don't just use mini fans to cool it, they have cooling element inside that cools the phone.
firesong
Deluxe Member
Since your phone IP68, soak in ice water la. Problem solved. /s
really_noob
It is the user problem not the phone problem. If you are using your phone normally (e.g. not hacked or trying to hack others) and correctly (e.g. not in the sauna room), you shouldn't need to cool it down manually. iPhone has temperature management system in place, does not mean that it won't get hot, if it does, the phone won't go exploding in your pocket.
dappercivility
I use phone cooler to attach onto the phone and cool it. especially when im charging it.
dappercivility
I remember there was once my phone got really really hot for no reason while in idle. I switched it off and threw it inside my fridge freezer for like 15 minutes. It was really cold and no issue with it after. Just something silly to share on the subject on keeping phones cool 🤣
doki81
can try this type. universal fan clip, will help reduce 2-3 celsius..
https://shope.ee/B6PafAr9J
sg-11134201-7qve3-lgtiwdh3hfsfeb
Arandalo
For passive cooling when charging, can put a reusable ice pack or heat sink on top of the phone display to reduce heat. If you want even more effective cooling then put the reusable ice pack or heat sink in the freezer first.
alex22
Fan. Small one will do, no need anything special.
If urs is metal body or frame, can thermal paste heatsink
firesong
Deluxe Member
