Pipo M7 Pro 3G tablet review
snoopydog
Hopefully the latest official ROM will fix the freezing problem and improve battery life.
What screen freeze?? I havent experienced any.Battery life is quite good so far. Ha ha...I am still on stock rom....Pipo hasnt officially come out with the new firmware ( Sep 2013 ) yet.
Riley is working on his latest 1.6 rom..hopefully this will be more stable than his previous ones.
But if new firmware can improve further..that will be even better :s12:
Got my M9 PRO...OMG FOR THIS PRICE ITS OWNS IPAD
Good to know you finally got yours...how many business days did it take in total...though I felt mine a bit longer than expected, but otherwise happy everything was intact.
Wow...sounds awesome. Do give some feedback about your M9 Pro. Thanks.
我猜我猜我猜猜猜
i think i really bad luck, i tried 3-4 rom already still got problem contact seller he kept replying the same stuff ( i think is autobot :s22:)
Wolong.
I'm using riley rom 1.6 beta for m9 pro, anyway the beta just means that the default apps and pipo family launcher is there. It's still the latest firmware just only with the default apps and lancher.
snoopydog
Who is your reseller?
But Pipo hasnt released any yet...probably still in its beta stages.
How is it anyway?
Huston
我猜我猜我猜猜猜;79480888 said:
screen freeze what u do to get out huh ? :(
Screen freezes, you need to reset tablet, else it will just drain off battery and shut off itself.
ZhuPaJian
Are there any pipo models to recommend? I am looking for one which is around the size of samsung note 8.0. Lte version yup
snoopydog
It sounds more like software issues....I can only assume you are experiencing the problems with custom roms?
Do you encounter the same problems with Pipo stock roms?
You need to diffentiate between hardware and software issues....your reseller cannot help you if its software related.
我猜我猜我猜猜猜;79512189 said:
Guy is there a way to auto restore the app u installed previously ?
You can try Appmonster, if this is what you are looking for... there are others as well...search Backup.
If you have rooted your tablet, Titanium Backup is good.
You can take your pick from here
Products--PiPO Tablet
Depends on your budget, specs required, usage and LUCK...U8 comes closest to the size, but reported by many users to have poor WiFI.
tan1688
snoopy, for your pipo M7 pro, do you encounter wifi
problems ? could you roughly tell how many bars
say one room away from wifi router, living room etc.
thank you.
also snoopy could you recommend the apps
that you install on your pipo m7 pro
e.g what browser that do not crash playing flash,
youtube, can it play netflix or video content
apps youku ?
snoopydog
Pipo M7 Pro RileyROM 1.6 is out now! :s12:
thank you.
apps youku ?
You can refer to my review in post #2.
Chrome browser comes preinstalled with this tablet, and has built in flash..so no problems so far.
Youku and Netflix is restricted, and in order to access requires VPN. You can look at the Riley rom thread above...the creator mentioned.."Netflix works, too...BTW. "...I have yet to try out.
Its depends on what apps you are looking for,... purpose??
whorocks
actually hor, y u all use roms and not stock huh? to remove default apps only?
new to this
我猜我猜我猜猜猜
Sian i gonna spend more money on my pipo the seller request me to ship back the tablet by AIR :(
Vincen Li
Mon Sep 16 20:40:21 PDT 2013
Dear friend,
Nice day.
Could you go to a local repair store to have it checked for repair? If the repair fee is under $5, we can refund the repair fee to you, since this is the most quickest solution to save lots of time and work. If not, please return it to us for repair.
Please check the following tips before sending it back.
1. Please return the parcel to us as soon as possible and provide a valid tracking number.
2. Please use the Post service, such as Airmail to us, otherwise the parcel will be stopped by the custom.
3. Order number, name and returned reason must be written down and put in parcel( And tablet should have a good protection)
4. Please full charge it before sending it back.
Here is our address:
ADD: 3th Floor, Block A, Haibin Industrial Park, XingYe Road, 65 Zone,Bao'an District, Shenzhen, Guangdong, China
TEL: 0086-186-8877-8776
ZIP Code : 518101
City: Shenzhen
Best Regards,
Vincent - Eternal Team
ZhuPaJian
anyone selling their pipo? my budget is 150~160 for a tablet with 3g function. yup...
