Please advise on USB3.0 and casing problem.
FinalTidus
Hi guys,
Before I explain my problem, please look at my rig===>
My mobo supports USB3.0. But my casings does not support any USB3.0.
Problem is I do not intend to get a new casing that has USB3.0 as it will be a hassle to change and also my casing is fine just that it doesn't support USB3.0.
Can I get a USB3.0 header or something to plug into my mobo/casing?
Please advise.:(
shadow84
Go find a usb3.0 to usb2.0 adaptor for ur mobo. Chamoxa or t258jgn shld have.
darkmatt
my secondary has the same problem. i just live with usb 2.0 lol
12122012
Cryogenist
Hi guys,
Please advise.:(
As long as your MB supports USB 3.0, just get those panel suggested by the others, those 5.25 inch one..
You have to patch USB 3.0 internal connectors to USB 3.0 panel to get USB 3.0 speeds.
Ark Law
Plug your casing USB2 into your mobo non-USB3.0 header lah. Deal with it. Life goes on without USB3.0
Or can go hoot those 5.25"/3.5" front panel with USB3.0 like others mention
trenzterra
Get front panel, or get USB 3 extension cable.
Somehow 5.25" panels are pretty hard to come by though :(
