Please help to recommend a ryzen build
kimutaku
Hi all,
Need your expertise to recommend me a Ryzen build.
Usage: light gaming, videos/web surfing, office word, light photoshop
Preference: ITX board (prefer a small casing), AMD graphics to take advantage of free sync from the monitor mentioned below.
As my dell monitor kaput, i thought of buying the LG-29UC88 monitor to replace.
Thanks in advance.
Psycovirus
Thanks for the reply. Probably less than 1.5K (excluding the monitor). :)
  • AMD R5-1600 + MSI B350M MORTAR - $468
  • Crucial Ballastix Tactical 3000Mhz C15 16GB kit - $219 (With Citi10 Discount on Amazon Prime Now)
  • Samsung Evo 850 M.2 250GB SSD - $149
  • Sapphire Nitro RX580 8GB - $479
  • EVGA GD SERIES 550W GOLD 5YRS PSU - $109
  • C.M MASTER BOX LITE 3.1 WINDOW CASE - $69
  • 2x C.M 12CM SICKLE FLOW-X BLUE / GREEN / RED LED FAN - $24
Total Damage - $1517
All Prices are quoted from PCThemes otherwise stated.
RAM Prices are a problem to fit into your budget. A month or two ago, the prices are about $50 cheaper.
If Amazon Prime Ram OOS, try these Klevv CRAS II from JC on Carousell.
kimutaku
Thanks for the recommendation.
Some questions here:
1) Do i need 16GB of ram?
2) is Rx580 overkill for light gaming?
3) I prefer a classy casing with a small footprint. Probably something like Jonsbo casing.
Thank you.
Psycovirus
Yes and No. It primarily depends on your use. Currently, 16GB is the norm. Hardly find any 8GB builds. Even Mobile phones start to have 8gb. haha.
For your monitor, at 2560x1080, no, not overkill. It's perfect for Ultrawide 1080p and should be future proof for another year or so.
  • SAPPHIRE RX 570 4GB NITRO+ - $399
  • SEASONIC M12II-MODULAR 520W - $99
  • Jonsbo UMX3 - $109
Total Damage : $1443
watzup_ken
I wonder what is the definition of light gaming here. What games are TS playing? For my light gaming, I only went for a GTX 1050 Ti which cost less than half the price of the RX 570 recommended. Runs everything smoothly, including games like Rise of the Tomb Raider @ 1080p.
kimutaku
Sounds good. Thanks man.
watzup_ken
Anyway, if TS really wants an AMD card for FreeSync, the I guess the best option is indeed the RX 570. RX 560 is significantly slower and poor value for money.
kimutaku
haha good question. Probably like planet coaster, those kind of genre.
Correct me if i am wrong, Nvidia does not support free sync isn't it?
kimutaku
Actually on the other hand, i thought of building a hackintosh. But it requires a Nividia card for initial setup.
hlots123
watzup_ken
Nope, it doesn't. That's why if that is your requirement, the best AMD card to get now will be the RX 570. However, it is still very pricey considering it performs worst than a GTX 1060 3GB in most cases and cost at least 15% more currently. At 399, you are talking about a proper GTX 1060 6GB price range.
hlots123
from later posts 2017, seems they'd fixed the freesync flicker for planet coaster :)
Every other game works without flickering, including GTAV, CS:GO, Kindergarten, Planet Coaster, Tom Clancy Ghost Recon.
https://www.reddit.com/r/Amd/comments/6ms6ky/freesync_flickers_still/
Little flicker in Anno 2070 and no flicker at all in Planet Coaster which are both based on different engines.
https://community.amd.com/thread/203760
kimutaku
In this case, will i miss free-sync? or it's a redundant feature?
watzup_ken
Quite frankly, for the type of games you mentioned that you play, I don't think it is a deal breaker not to have FreeSync. If that is the case, I think you should do well enough with a GTX 1050Ti.
