Please help!
k3nshi
Guys, very suay. 2nd day of 2017 face with this problem
I was playing FM17 half way and the screen display go crazy and restarted. It booted up and the windows repair can't resolve the problem. So i went to restart a few more times but to no avail. It just went into that blue screen and can't get into desktop. weird thing is something the rig is running but it makes my monitor go into power saving mode.
Does this mean that my GPU died?
Any kind soul able to help?
Thank you in advance
k3nshi
Sorry, if i plug it out. Then i can't see any display? or do i have to borrow a GPU to try out?
Koenig168
Your MB has no onboard graphics so you will need to borrow a GPU to test.
ZrE0_Cha0s
Well if your gpu isnt woeking properly anymore. Maybe its time for u to buy a new gpu.
k3nshi
I think I will just borrow a gpu from friends and try it out.
Is there anyone can help with ttroubke shooting?
ZrE0_Cha0s
u can bring down to nigel shop @sls lvl 2 to check with them whats the issues.
k3nshi
Thanks to all the bro here. I have gotten a GPU from friends and it works fine now
