Pls Help Old Uncle to choose MVNO
whitesand
Hi all:
Old uncle need recommendation for Singapore mobile nos to be used in US, for about 2 years, but do not wish to change Sg mobile nos.
I need the sg nos for OTP and keeping Sg local contacts, do not intend to change nos even when I am in US. I will get a US sim for US call/mobile data usage. But my current sg mobile nos is traditional plan (no more contract) and it is quite expensive to keep for 2 years. I wish to change to a MVNO to cut down the cost of holding sg nos since I will be only using it mostly for OTP and emergency contact, while mobile data I can use wifi or US sim.
I have a few question and hope that kind souls here can help:
  • Can I receive SMS & OTP while in US using MVNO basic plan?
  • What happen when someone call my sg nos via voice call? I don’t think it can go through right? Will there be a missed call message? I understand that call via Whatsapp can be done as long as there is network.
  • Any recommended MNVO / plan? I am looking at those around S$10 plan.
Thanks in advance for all help.
BBCWatcher
SIMBA and Eight both include roaming service in the U.S. Eight is data only in the U.S. at the moment (unless you happen to pick up an old T-Mobile 2G signal, which won't last long since it's being phased out). SIMBA includes VoLTE service in the U.S. for voice and SMS. If "old" is literal (age 60+) then SIMBA is only $5 per 30 days (Senior Plan). Eight is $8 per 30 days regardless of age.
M1 Maxx also includes some roaming data and minutes in the U.S., although it ends up being a bit more expensive after 2 years (average of about $8.90 per 30 days).
(Edited to clarify that Eight is data only in the U.S. at present due to a recent change in roaming partners.)
A7997A
Simba partner in US :
  • AT&T / 310410
  • T-Mobile
  • Verіzοn (5G & VoLTE)
Eight partners in US, none has VoLTE :
AT&T Mobility, Sprint Nextel Op, T- Mobile
I would say Simba would be the better choice here, since Verizon supports VoLTE & Simba has superior VoWifi compared to eight, so as long as you have wifi you should be able to receive calls.
Simba $12 plan provides 8GB of roaming data in US, so unless you are really using a lot, it should be enough.
mosmos
High Honorary Member
BBCWatcher
Heya's SG60 promotion for seniors is a competitive offer. However, it would not meet the needs of the original poster who wrote that he plans to roam in the United States.
hwsstx
Hi all:
SIMBA suits your description... Seniors Plan is $5 a month.
Edited
Incoming SMSs are free. Outgoing SMSs are not supported while roaming.
hwsstx
Can receive SMS but cannot send SMS
• If you are overseas and making a call to a local line in the destination you are in, the deduction will be made from your IDD minutes.
• If you are overseas and making a call to a landline in Singapore, the deduction will be made from your fixed line minutes.
• If you are overseas and making a call to a mobile line in Singapore, there will be no deduction. The service is free of charge.
https://support.simba.sg/hc/en-us/articles/4415874442777-Are-international-calls-and-SMS-supported
