Poco M3
BirdbrainZ
if poco x3 is similar price, get that instead of rmn9. it has better software
Thanks. I was eyeing the PX3 actually for the NFC function, but the price point was closer to $3XX range instead of being in the lower $2XX range or upper $1XX range which is closer to my budget unfortunately.
kazuki666
If like this compare. Local set 128gb m3 is cheaper than hk set 128gb x3 by ard $50, chances I may go for x3 seems more realistic lor... Camping see if black Fri or 1212 can get back that good price x3...
Sent from Xiaomi POCOPHONE F1 using GAGT
matrix05
I see performance is an issue too. Not sure if it is cause it's pre-release software or...? Need see more reviews to be sure.
Posted from PCWX using Redmi Note 8 Pro Ocean Blue
Agree. Maybe no rush for m3 for Bfcm, wait for more video review; 12.12 then 25.12 are coming.
BirdbrainZ
Any ideas what the upper limit of expandable SD storage can be? I'm considering buying the 64gb version and getting a SD card to expand the storage later.
Audiology93
Poco x3 is $259 right on Qoo10 after using $30 coupon. Another 10% rebate by using grabpay and it will cost around $236.
Sent from Samsung SM-N950F using GAGT
Audiology93
512GB
BirdbrainZ
Oh, that is nice. I'm kinda unfamiliar with how Qoo10's coupon system works. Where do I get these coupons, and how does grabpay work? Thanks in advance for any guidance given.
BirdbrainZ
512GB
Does "Up to 512gb" means I can buy a 512gb SD card to expand the storage - meaning base 64gb + 512gb SD card, or does 512gb minus 64gb means I can get a 448gb and lower SD card to expand the storage? Kinda new to this.
kazuki666
But do app takes up internal memory space? Don't forget WhatsApp takes up fair bit of internal memory too. From my current situation with F1, I realise 64gb is quite challenging tight...
Ye_Rongtian
App take up internal memory space. SD card is mainly for storing photos, downloads, videos. Unless you want to format your SD card as internal in which the speed will suffer.
kazuki666
Other than app, for me WhatsApp is a big killer. I think easily take up more than 20gb internal memory. Kns it doesn't backup to external memory de... :(
Audiology93
Yes you can buy a 512GB microSD card and put it into the phone in additional to the internal memory in the phone
rootz
Wah. So much videos within?
U can clear the chats mah.
kazuki666
Actually I am not savvy with the app. If I clear, it means I can't see the videos and pictures sent to me previously liao right?
Ye_Rongtian
Save the video to SD card. 20gb easy to get corrupted
