Pocophone X3 Pro
Angtehkor
Do you guys charge to 100% then setup phone, setup phone then charge to 100,% or setup, use until 20% or less, then charge to 100%?
My phone come with 70% battery, I setup phone and use first as they are still battery left, then morning wake up charge my phone. As I prefer to charge my phone in the morning.
LobsterX
first time with a side fingerprint scanner. which fingers do you guys usually record? left & right hand index finger, and right hand thumb?
Right hand:
Thumb, index, middle finger.
Left hand:
Index, middle finger, thumb.
All registered as 1 fingerprint.
ZhuTou!
No diff
Setup phone wont take much time also
Usually i setup first coz the phone will have lots of battery inside
frizee
Hoseh my 25th Mar order is being delivered by courier liao :D
Thanks for all the useful tips share here!
KeYoKe
Battery try keep it between 20 - 80% charge, else is to try not to keep it at 100% charge for too long (for exmaple charging overnight)
KeYoKe
The X3 pro screen is surprisingly good... very fast and snappy phone for the price
i very worried about the LCD screen... have been using amoled screen for too long le... let me see whether to unbox and try when i receive it later
twosix
nothing to worry about. I can't really tell the difference on my x3 nfc. except the max brightness under bright sunlight cannot make it.
ZhuTou!
Lcd just brighter la
Can tell the diff since u use amoled before
Avoid using under sunlight can liao
Very hard to read
paul02
Ya need wait like 7 to 10 days for the stupid countdown timer :s13:
7 days.
Worth the wait though. Installed ArrowOS and everything is buttery smooth, no ads, no bloatware, no frills phone.
KeYoKe
Very hard to read
:s13: ya. can only psycho myself that this phone is not expensive
7 days.
Yup, there are a few custom roms which is quite good. one of my favourite used to be pixel experience. I might just apply to unlock bootloader when i first got the phone. But to unlock or not depends on if there is any custom roms worth flashing, else is flash xiaomi.eu rom (but if thats the case must as well i stick to stock rom)
thanks for the assurance bro :s13: let me see for myself later
badstudent
R the dimensions of x3 and x3 Pro the same? Thinking of buying privacy sp but seems like only avail for x3.
Realised alot of people trying to flip the launch sets for a profit on carousell too.
KeYoKe
its the same dimensions...
good luck to those, those whom get pocophone has done their research one as usually they are tech enthusiast. i only saw 1 letting go at his cost price so far
Ye_Rongtian
The guy selling at $262?
badstudent
Thinking of getting the 8gb + 256gb instead, love the physical fingerprint sensor as compared to the rest which is all in screen sensors.
ceestudent
Can low ball them for 220?
Devilsire
Anyone knows how to hide/disable the work icon when workmode is off, or it can't be hidden?
