Popping Noise
farron111
Hi guys,
My speakers tends to produce a popping noise every single time my pc is turned on.
Just wanna know if there is any solution to this?
wwenze
Not really, and it's not really an issue either.
Using a soundcard or DAC that has a bipolar power supply (i.e. not your Audioengine D1) can avoid that. Equipment with soft-start or output protection relays can avoid that. But it really isn't an issue anyway so wtv.
jtjt00
Workaround solution like turn on speaker after desktop boot up eliminate the popping sound issue.
