Portable battery for Notebook
in1voice
I have a Samsung notebook that does not have a removable battery. I need a portable battery that can charge the notebook where there is no power outlet available (eg. on the plane).
Can anyone recommend a reliable portable battery charger for notebooks, and where to buy from?
86technie
Other than Macbook/HP which there is portable battery.
Windows laptop doesn't have, key issue is that most
are using AC input to provide power.
Just bring the charger along, when you reach the hotel
than charged.
If you buy a powerbank, there is no way you can charge
the laptop.
If you feel troublesome just get a tablet or surface pro (Windows tablet).
LonelyMan
Some airports or airlines has limit on the size of the power bank. For example in Thailand, they have a limit of 20000mah x 3.7v or about 74whr size.
Ravpower has many models for you to plug ur ac adapter. However this is not power efficient. Best is to get one with the right connector for your laptop to do direct DC powering ur laptop.
Actually power adapter at Starbucks and airport is more simple, or use a tablet with USB charging.
