Possible Heat Issue?
Majestic12
Recently while I have been gaming, I have been encountering problems whereby the game would freeze and the screen would hang before going pitch black. No way to exit to desktop other than to do a hard reset.
Using the PC for web browsing, music and watching movies doesn't have any problems. It's only gaming.
After reading around, I suspect it may have something to do with temperatures being too hot internally. Cleaned the air vents but to no avail. Went into the BIOS and found the following:
imgur: the simple image sharer
Is it normal for CPU temperatures to go as high as 67 degrees C just on bootup?
As my rig is slightly over three years old, I suspect perhaps the thermal paste on the GPU has also decreased significantly? Especially with occasional periods of intense gaming?
Appreciate any advice, thanks in advance.
jtjt00
I think both CPU & GPU stock thermal paste dried up over 3 years.
Remove old thermal paste with IPA and apply fresh drop.
jtjt00
This is kinda too hot, from cold condition power up should see temperature not more than 40°C.
....Is it normal for CPU temperatures to go as high as 67 degrees C just on bootup?.....
devilwahaha
67 degrees is a bit too hot for idle, your chip should be idling in the range of 40-50 degrees at the most at stock clocks. Cleaning the CPU heatsink and the fan, and reapply the thermal paste should fix the problem.
Majestic12
Thank you all for the advice. Is there a recommendation for where to do the cleaning and paste replacement? Am also looking at possibly upgrading GPU.
