Post your rig!
darkarn
Here's what I am using:
Headphones: SCOSCHE® HP153md
Audio Sources: Laptop | HTC Desire Z
Now looking for an entry-level below $200 DAC+amp combo (hence my thread) and portable recording solution.
weng
Hey Weng, how does the M1HPA sounds? It looks pretty solid...
the built is good indeed. only gripe is the line/usb switch lever. looks quite obiang in modern day design especially like this m1hpa. thought they should at least put button like the on/off button. there's a usb input to connect digital sources directly. it also has pre-out/line-out outputs that i can loop back to my pm6003 (now disconnected cos dun have another set of interconnect) if i want to play aloud through speakers (although hardly used).
sound wise i tested this with the x-can v8 before choosing this. v8 noticeably sweeter with vocals since it's tube based. m1hpa has slightly better resolution and it's livelier, while staying quite neutral-warm.
my quick impressions comparing the below permutations at home:
interconnect: ecosse "composer".
cd6003 -> pm6003 -> ath-pro700mk2: airy.
cd6003 -> m1hpa -> ath-pro700mk2: slightly airier but noticeably better controlled, sweet vocals.
cd6003 -> pm6003 -> hd595: quite airy, slightly warm.
cd6003 -> m1hpa -> hd595: airier, thinner and more neutral, but can sound a bit hollowish depending on genre. bass is still there but the body is lacking.
cd6003 -> pm6003 -> hd650: thick, warm.
cd6003 -> m1hpa -> hd650: more neutral/slightly less warm, thinning out abit is ok since it's thick to start off with, really opens up and noticeably better controlled yet with a darker background, sweet sweet vocals and highs. but hd650 bass still not very pronounced (i dun mean heavy/light).
still running-in. overall it's a very sweet and big sounding amp typical of MF's sound sig, seemingly with lots of power in reserve driving the phones effortlessly.
however i also played through ie80 and it doesn't really like it. made the bottom a bit overloaded drowning out abit of the mids/highs/detail. still sounded better off the iphone4 and my sony dap.
also just tested with a px 100-ii, and sounded quite good. makes the overall sound better controlled, more detailed, although still a bit bottom heavy.
weng
replacing my struggling 4gb sony... always gotta find things to delete in order to add new songs. :s27:
ex-1000 wannabe :D
and damn sony... why charging cannot use??? old one like that, new one still like that!
weng
Ex600 looks dam nice....
actually it's a fail in ergonomics, yes together with the ex1000 since they are of the same concept. sounds quite horrible out of box too. gotta run in and see how.
Guan22
I remembered my EX-1000 sounding terrible from the box as well.
Give it 30 hours and it absolutely starts to sing. Very airy. Doesn't isolate particularly well but it does sings very beautifully.
Koelsch
if your ex1000 can sing, can i buy it then i put it for concerts? :s34: :s13:
a singing earphone might make me alot of money :D
weng
now i'm having fitting problem. bulky driver clumsy hanger just couldn't get it stable. even the ex300 from the player is difficult (this will be similar to the xba style). how i wish they can have the fit of my ex90. this earphone is simply the easiest/fastest + best fitting (doesn't mean isolating) phones i've tried so far.
weng
in the midst of running-in i've picked up and listen every now and then like night listening or when go shiit :D... still sounded quite horrigible, thin, bright and far. i use my usual 3 sets of music as a gage, olivia, freedom bossa and maroon 5. maroon 5 is the trickiest. very ear piercing. so far even my ex90 and ie8/90 still haven't got a grip on it. somehow it just poke your ear with every drum beat. the px 100-ii does maroon 5 very well.
just crossed the ~35hrs mark. i just picked it up after coming back from lunch. waa... i think i'm listening to another different phones. nice. olivia is much sweeter and full. maroon 5 still not very comfortable (i think abit more like genre mismatch) but much better. will try to run full steam. eager to see if this is going to be the 1-for-all earphones, once and for all (i hope :D). i tried settling with the ie80 but sometimes the bloated lows can be abit annoying.
