I can tell you prebuilt PC's 300-350W PSU is a whole lot better than chapalang Vios/ GameMax brand "500W" PSU. They actually deliver what they claim to and they last fairly long. Wattage is literally overrated in the DIY PC world, which is what chapalang PSU brands capitalise on with "500W" to get you to buy them.Honestly to be fair many user of pc especially from the pre-built system will not concerned about psu because it never be part of the advertised specifications as well as not much details in the user manual too.
Unless the user is adventurous to open up the case and check the PSU power and rating otherwise most of these specifications will surprised everyone how under power it was compared to the DIY power user even it was using high end GPU in the pre-built.
Pray tell who is committing this mortal sin of pairing a high end graphics card with an FSP PSU.Or worse buy second hand PSU which have been used for maybe 5 - 10 years without warranty.
Some mindset is if PC can work can already no need to spend so much.
While some budget is focus on having the best graphic card but other parts especially PSU
are skimp.
I do saw builds with a high end graphic card but paired with PSU like FSP.
Need not name these builders, some may know who.
What is wrong with FSP PSU? My last two PSUs were FSP made, the Aurum S and the current EVGA G+. GTX 970 and RTX 3070 also never explode.Or worse buy second hand PSU which have been used for maybe 5 - 10 years without warranty.
are skimp.
FSP won't explode but a few I encounter.What is wrong with FSP PSU? My last two PSUs were FSP made, the Aurum S and the current EVGA G+. GTX 970 and RTX 3070 also never explode.
Absolutely nothing, I was being sarcastic.What is wrong with FSP PSU? My last two PSUs were FSP made, the Aurum S and the current EVGA G+. GTX 970 and RTX 3070 also never explode.
FSP is usually found in prebuild system, in most cases, I don't find anything wrong with them. None failed over the years as well in my experience.FSP won't explode but a few I encounter.
Died after a year of usage.
i think the risk is low in sg, doubt anyone here uses a Gigabyte branded PSUs.
You are right. Usually those "prebuilt" is so call the true power rated PSU. DIY one many of the rating is so call peak power output.I can tell you prebuilt PC's 300-350W PSU is a whole lot better than chapalang Vios/ GameMax brand "500W" PSU. They actually deliver what they claim to and they last fairly long. Wattage is literally overrated in the DIY PC world, which is what chapalang PSU brands capitalise on with "500W" to get you to buy them.
