Wouldn't that cause health issues since you will be in a confined area with the air-conditioning turned on.Spray fins with bleach and let it flow down pipe. But smells of bleach for a while.
Can use 3% hydrogen Peroxide oso as it's odourless.
Or use 70% or 99% isoproypl alcohol to kill off algae that clogged the drain pipes but oso leaves chemical odour for awhile.
Hydrogen Peroxide and Isoproypl Alcohol (IPA) easily available online.
For me, I used the combination of all 3. Recently bought this Cleanbee for aircon solution which I think is caustic. Oso good but the odour lingers and needs to rinse and flush off to remove as much as possible.
And definitely never use boiling water, sure can damage the aircon plastic or pvc drain pipes. Not to mention scalding ownself in the process.
If u use chemicals, turn on the aircon in fan mode with max speed and open the windowsWouldn't that cause health issues since you will be in a confined area with the air-conditioning turned on.
U can use alkaline cleaner. 4L less than $10Spray fins with bleach and let it flow down pipe. But smells of bleach for a while.
It's not "don't know", like I say earlier it's usually the stingy-ass type of home owner who wants to do appliance maintenance without spending a single cent extra.*****…..he didn’t know there is a thing known as wet dry vacuum cleaner
No, if you know what you are doing.Wouldn't that cause health issues since you will be in a confined area with the air-conditioning turned on.
Ventilate the room by opening windows/doors and use fans.
I flush with continous RO water using my DIY 8 stage RO/DI unit of 800gpd capacity. Stainless steel fins tends to deteriorate using our tap water in the long run. SS and salts are not good.
I also use RO water to maximize dilution of the chemicals.
I like to delve in DIY stuffs, I know it can be a curse but I can't stop learning and wanting to try new stuffs through research and try.
I'm cursed to DIY everything and anything I can get my hands on.
Pressure spray cost money... and time to use...The typical giam jee sai + dunno wtf he's doing spotted.
wet/dry vac, pop it onto the drain outlet, then turn on 20mins.
then tiap the cover, use low pressure on karcher pressure spray, spray and then use brush with a PH Neutral cleaner, scrub blower, spray, scrub and spray.
then once done, turn on wet vac, suck out all the residue water from the pipe.
settled.
It is like the Tengah syndrome, water leaking out of the water coolant pipes.NEVER use hot water for AC pipes. you will spoil the seals between the pipe joints which will cause your pipes to leak within the walls.
