power button led on when switch is on
dynamojack
power button led on when switch is on but can't start
Hi, damn suay this thing happened to me just one random fine day.(ytd)
No other lights i see on, when i press the Power nothing else happens. so now can't start up..does anyone know what part of my com is faulty? Ima true IT tard too...:(
Com bought year end 2011 (cashtronic)
Biostar tp67b+
Fsp aurum 500 gold
Basically followed the rig which is stickied now...$8XX
Mr.Eric
Check your connection of your power button. If possible, try shorting the power button and ground pins on ur motherboard.
dynamojack
I'm using ikonik soho2...how do i check the connection and try shorting it? ( don't really understand those terms sry)
Mr.Eric
You say no power when you try to power on the computer right? What I suspect is that the wiring for the power button has came loose and there's no connection between ur button and motherboard.
Shorting the power button pin and the ground pin with a metal piece like screwdriver to check if really it's the connection problem.
Here's a tutorial on how to do that.
https://www.youtube.com/watch?v=BZqunOrUWeM
dynamojack
Yes!! It turned on again thanks so much! But for a long term solution what should i do?(how to wire it to the mb or power button?)
Mr.Eric
You can have someone fix it at a small price or DIY.
Basically unsolder the wire connected to your switch then solder a new wire to the switch.
dynamojack
Oh...those are unfamiliar terms to me again lol, can it be learnt through youtube vids?
wtfh4x
Yes soldering can be learnt easily through youtube. Soldering iron is $8 and the solder $1.50.
dynamojack
Alright! I shall try some vid learning first, if i cmi shall go find this relac corner....thanks for all de responses!!
