Power LED flickers
Viridian6
Yesterday I came home to find my PC had failed to enter sleep mode and was still on but with no light from the Power LED. (The ethernet connection had also malfunctioned).
After rebooting, the Power LED does give some light, but it flickers and definitely is not as bright as it used to be. The PC itself still seems to run okay.
Is this something I should be concerned about?
jtjt00
You can try reseat the 24/8-pins connectors to the motherboard.
