uniquely_ad
- Dec 10, 2011
updated. new
Hello recently i bought another new z5500 speakers and the power plug unit its from U.S is there any shop in SLS i can go to make it compatible with Singapore power socket? i have tried using the travel adapter it can slot in but it doesnt work?
the seller said i need to use a transformer? i dont get it
If your set only support 110V and have already tried using passive adapter, then really GG.Thanks for the reply everyone, so if i go to sls what do i need to say?
To the bro who asked me to cut the wire, bro i do ethernet cable aldy having difficulties what more doing this hahaha!! Sure i headache![]()
If your set only support 110V and have already tried using passive adapter, then really GG.![]()
Kandinsky, we need to match input voltage to the desired output. In this case we need lower input. Therefore we need step down transformer. Not step up.
I think there is still some hope for TS? the pic show that there is a fuse there? prehaps maybe only the fuse is blown. Maybe TS wan to remove the fuse and try to replace it and also to get a step down transformer? abit tedious. haha..hope after buying the transformer, the price is still lower than that in singapore.
wah bro u serious? den now how what should i buy first to test it
Not sure if it's difficult to get a 125V rated fuse here.I cross my fingers that everything will be alright..i will buy the step down transformer from sim lim tower later..the fuse how to buy
