Power plugs in phuket
taquito
Are the power plugs used in Phuket same as Singapore? And do you guys recommend to carry extra cash or just use CC if run out? CC got lots of extra charges? Thanks in advance!
Andrew833
Power plug is different from sg, you can google it.
Cash is king, and easier to use. I always carry extra cash in case you need it, can be few hundreds up to u.
CC mostly use for expensive stuffs.
kurtgoh
any recommendation for multi travel adapter?
best is with usb port for hp charging
beanstalk6
Moderator
Moderator
I prefer to buy the dedicated adapter- eg 2 pin to 3 pin. For the price of 1 multi-type adapter, you can buy several of these. The multi-type do not always fit well, and many are simply too heavy or big.
Andrew833
Agree, 2 pin just too weak to support all the weight. I got 1 muti - 3 part type, pick 1 to use, will fix nicely, then add a muti adapter. Can charge 3-5 devices.
kurtgoh
any sample/pictures?
i notice Thailand, vietnam uses all differently..
Jeremy1
