Power Supply recommendation for my rig?
CrowsZero
AMD Phenom II X4 955 Black Edition
Intel SSD 240GB
Zotac 750 Ti
8 GB Ram
Was looking at lazada but don't know which brand to get :(
CrowsZero
so u mean u want a lower psu rating? like 300~350w?
i dun think its good. minimum best have a 500W though.
I mean, how about motherboard and processor any recommendation.
For PSU i might go overkill abit like 650watt incase of any graphic card upgrade in the future :s13:
yusoffb01
U can consider fsp aurum gold and avoid cooler master or seasonic.
jtjt00
TS, you need only PSU or the full list in first thread?
ZrE0_Cha0s
@_@ i though u just want a PSU??? since u say a PSU for your rig....
CrowsZero
I need PSU, Processor and Mobo.
Because my rig is faulty and this are the two parts which i don't have a spare com to test.
I have tested my gfx, ssd and ram and they are working.
kaixax555
Well it's time for an upgrade so why not get an nice new mobo :s13:
you want keep RAM or upgrade :s22:
ZrE0_Cha0s
Den may I ask what are usage on the PC? the case u using? Or gonna buy new? Lastly what are the features u required from the mobo?
+what's your budget?
MoneyFace =p
CPU and motherboard can tu till next February? Give yourself more choices and a chance with native USB 3.1 Gen2 out of box...
royfrosty
Seasonic you can go for x series or p series or prime series. But of cause that is if you willing to pay top dollar for their psu.
MoneyFace =p
TBH FSP Hexa+ is good enough for a low energy consumption PC...
I'm using one now for almost 2 years...
