Power switch problem.
leehuaqing
Hi guys, I'm unable to turn on my pc pressing the power button.. Using the Sharkoon VS3- V Case.. Any place to repair the power switch button?:(
leehuaqing
Update: After 30mins of pressing the power switch button, it back alive.. But the problem, is it wear and tear issue? Because when i just bought it, just need 1sec to on it... Recently need to long press it then it will turn on (After 3-4secs)..
Now it's ok, but scared after switch off liao the problem resurface again.. any solutions experts?
Gymrat76
You can buy replacement power switch from shops in SLS. But need to solder yourself. Else can just use your reset button as suggested
leehuaqing
Does you casing comes with reset switch?
Erm.. I do not know..
kyuushin
probability of a faulty psu or motherboard is higher than a faulty casing switch tho...
leehuaqing
Hi guys, problem came back again. Been pressing for past few hrs also cant power up.. Last night still ok.. Now totally cant on
Any shops to recommend to fix?
wwenze
So now reset button dieded also?
Use screwdriver to start it and never off it ever again
Or use bios to set turn on using keyboard
Koenig168
Might be cheaper to buy a new casing.
Morugana
alternatively i would solder a bishi bashi style arcade button as my power on switch.
first thing reach home whack the button to boot my pc
simcher
so sure it is the power switch? this can happen to faulty PSU too..... i ever come across a computer that doesn't power up when you just switch on the mains.... but after waiting for 15mins or so... you can start the computer...
