MrSinkie95
- May 20, 2015
Hi, is it true that there's only 3 stations now for the NAPFA test? How much points do we need to achieve Sliver/Gold?
I believe it meant that you will still need to do the standard 5 Static and 2.4km run for NAPFA with the Pull being changed to Push Ups.With effect from 1 March 2015, the three-station Pre-Enlistee IPPT will be used to assess pre-enlistment fitness. Pre-enlistees who attain 61 points or more from the three IPPT stations in the 12 months before their enlistment date, and who are medically graded PES A/B1, will be eligible for exemption from the 8-week Physical Training Phase (PTP). Those who fail to attain the required fitness level will have to undergo the PTP before attending the 9-week BMT.
http://www.ns.sg/nsp/web/esvcs/mind...&_afrWindowMode=0&_adf.ctrl-state=4k0isd3dx_9
this one for what?
download the new ippt app on playstore/app store
No such thing as IPPT for pre-enlistee.
You take NAPFA.
NAPFA still the same except pull up changed to push up.
Six Stations.
Then only the three stations that are being used for the IPPT namely, Push Ups, Sit Ups and 2.4km will be counted.
Mr Sinkie not yet enlist so is called napfa. And napfa got 6 station. No such thing as pre enlistee ippt.![]()
Are you physically fit? If you have been medically graded PES A or PES B1, you are encouraged to take the three-station Pre-Enlistee IPPT.
In the modified NAPFA test implemented since Jan 2015, MOE has replaced the pull-ups station with the push-ups station. The modified NAPFA test now comprises the three IPPT stations of Push-Ups, Sit-Ups and 2.4km run. The results of the three IPPT stations will be transmitted to CMPB. The six-station NAPFA results with pull-ups will also continue to be accepted for those who had taken the older NAPFA test earlier in their schools.
Pre-enlistees can refer to the IPPT scoring table for the number of points they can attain for performing a specific number of sit-ups and push-ups, and for completing the 2.4km run in a specific timing. The maximum score is 25 points for the sit-up and push-up stations, and 50 points for the 2.4km run. The minimum score for each station is 1 point.
The three-station Pre-Enlistee IPPT is conducted at the Toa Payoh Stadium (map to Toa Payoh Stadium) every Wednesday (except public holidays).
You are required to book an appointment for the test via the Pre-Enlistee IPPT booking system prior to the test date and you are only allowed to make one booking at any one time.
Please note that the Pre-Enlistee IPPT results are valid for one year from the date of test. Please report for the test in sports attire and punctually.
Tests at Toa Payoh Stadium are conducted strictly on appointment only. Therefore, advance booking via NS Portal must be made latest by Tuesday before 12 noon in order to take the test at Toa Payoh Stadium the following day.
Do note that pre-enlistees who do not book their test date via the system will not be allowed to take their test at Toa Payoh Stadium.
If you wish to know more about the three-station Pre-Enlistee IPPT, you may want to read through the FAQs before you make your booking.
Smlj you all talking about? It's called Pre-enlistee ippt on ns.sg and contains three stations; Push up, Situps and 2.4km
Refer to below
