sAxman_Returns
- Dec 21, 2005
HP M551DN ?
just curious.
What are you going to use the printer for?
- high quality magazine brochure type?
Quantity print per day?
Phaser doesn't ship from Amazon to SG to the huge box size and weight.
To be honest, I don't think the savings will be that incentive, since there will be no warranty, and that's important
Furthermore, government PIC grant should get a 100%
http://www.iras.gov.sg/irasHome/upl... Automation Equipment List (as at 270911).pdf
You can opt for installment plan from fuji Xerox directly
If you are going for those type of professional brochures, I think you should be looking at an entire different range
Graphic Communications Production - Fuji Xerox Singapore
Note: sorting / folding machine doesn't fall into PIC grant
Its very expensive to print brochure using colour laser. This is because toner is expensive (even though printer is cheap). If you need to print in bulk, recommend you to get a printing company to print for you instead.
Try to get a xerox laser color using toner, not phaser (solid ink).
Longest warranty i believe of 4years
Among the cheapest across the same range.
Best image quality
