Hi, appreciate any advice on the best setting for OSD -> Picture Quality Setting -> Response Time -> [Off, High, Middle, Low].
Does High mean highest or lowest(best) response time? Or, does Low mean the lowest(best) response time?
What does the Off option even mean?
OSD -> RGB Full vs Limited. Full RGB looked more washed (less constrast) out than Limited RGB. Is that normal?
Thank you!
Thank you!
