Pro Advice on Building New PC
Jeff85s
Hi Everyone,
I am a newbie to building a PC given that my last build is in 2012 (via advice from Pros here). I did some research and generated the following list (as below) hoping to seek for some expert comment or suggestion please.
- Gigabyte B760 Gaming X AC DDR4
- Intel Core i5-13400F | 10 Core 16 Threads
- Gigabyte RTX 3070 Eagle OC - 8GB
- 2x 16GB ADATA Spectrix D45G DDR White
- Cooler Master Hyper 212 White
- WD Black SN850X NVME
- Superflower Leadex III Gold 850W 80+
- Corsair 5000D Airflow TG White Casing
My purpose is to build a PC for gaming (e.g. COD MWII) that can last for about 10 years (with minor upgrading along the way) if possible 😁
Not a heavy gamer. Maybe 6 to 8 hours per week. Budget will be between 1,800 to 2,000. I do have 1x Seagate BarraCuda 4TB 3.5 inch HDD avaliable and are thinking of using it as games storage while using WD SN850X as Window drive.
Thanks in advance.
NightRaven49
cant comment much on this setup without pricing context. however, i would say that a 3070 with 8gb of vram is probably not going to last very long and a 850w psu is quite overkill for this level of performance.
i suggest u take a look here:
https://forums.hardwarezone.com.sg/threads/pc-rig-recommendations-for-2023.6852056/u have 2 options, can pluck either the midrange 1.3k build and upgrade the nvme to the sn850x from pc themes, or the high end 2.2k build and swap out the 4070 for the 6700xt from the 1.3k build. either way, u get a very potent 6700xt build, with its 12gb of vram a safer bet vs the 3070 and it performs better than even the 3070ti in cod mwii. the 5600 is comparable to the 13400 in gaming, while the 7600 far surpasses it.
Jeff85s
Hi NightRaven,
Thanks for the advice and recommendation.
I have plucked and mixed the list as below.
- Gigabyte B760 Gaming X AX DDR4
- Thermalright Peerless Assassin 120
- G.SKILL Trident Z RGB 3600MHz 32GB
- ASUS ROG STRIX Radeon RX 6700 XT 12GB
- WD Black SN850X NVMR
- MSI MPG A750GF
Will this be a better option or is it still way better to go for all out with AMD? In terms of long lasting, will Intel last longer then AMD?
My apologies if the question is a bit noob as i am not very good with all this and only heard that intel can last longer then AMD.
Thanks in advance and apologies for any inconvenience caused.
kaixax555
Hi NightRaven,
- MSI MPG A750GF
no such thing, CPUs just run shorter if you run it at elevated temperatures all the time, otherwise they should last about the same
Looks ok for the most part, do consider a DDR5 option though:
Asus TUF B660M-Plus WiFi D5
Kingston Fury Beast DDR5-5600 2x16GB CL40
Goodshot
I see youtube 7600 is 5-10% faster and cheaper by $50 , if me i would go 7600
NightRaven49
it depends on other workloads u do on ur pc. if u do a lot of multithreaded work like video encoding or 3d rendering, the intel option would serve u better. but if ur just gaming and general use (eg. web surfing and watching video), the 5600 is cheaper by a substantial margin and provides basically the same experience, so that would be the obvious choice for me. if ur already planning to use ddr4 for intel then imo intel doesnt have any futureproofing advantage either. take note that the 13400f cannot make full use of the 3600mhz ram in gear 1 too.
also why would u choose a strix 6700 xt? thats really overpaying for a gpu, other aib cards (esp amd exclusive ones like powercolor or sapphire) have better options for cheaper.
Jeff85s
Hi Kaixax, Goodshot and NightRaven,
I think i will just go with the recommendation list (as below) based on all your great advice and recommendation.
- Asus Tuf Gaming A620M + Ryzen 5 7600 Bundle
- MSI MPG A750GF
- Corsair 4000D Airflow TG
- G.Skill Flare X5 2x16GB 6000 DDR5 Expo
- Powercooler Red Devil RX6750XT 12GB GDDR6
Beside Asus Dual RX6700XT, are there any other good GPU recommandation (e.g. one with 3x fan 😁) for this type of setup? Is Powercooler Red Devil RX6750XT 12GB GDDR6 equivalent or better then Asus Dual RX6700?
Thanks in advance.
ragnarok95
Senior Moderator
Senior Moderator
The RX6750XT is a more powerful card than RX6700XT and in some case win even the RX6800XT. You can also consider RTX4070.
abstrax
Hi Everyone,
Thanks in advance.
Y not get RTX 4070? Using HDD for gaming is not an ideal recommendation. Best is to use back NVMe SSD for best performance. HDD is generally used for storage now.
Jeff85s
Hi ragnarok95 and abstrax,
RTX 4070 are quite expensive. I think i will go for Powercooler Red Devil RX6750XT 12GB GDDR6 for now. And to upgrade it when necessary in the future. 😁
Thank you.
Phen8210
Actually, if u plan to upgrade short term maybe get 2nd hand gpu better?
ragnarok95
Senior Moderator
Senior Moderator
Yes, can consider 2nd hand RX6700XT with warranty from carousell. They are going for around S$400+ now.
Jeff85s
Hi Phen8210 and ragnarok95,
I think i will stick to buying new one as if can I will like to keep to this GPU for around 5 to 6 years if possible. Not a heavy gamer nowadays. 😁
I also just found out that not all motherboard support Windows 11 (I think Asus A620M doesn't). Given that Windows 10 are reaching EOL in 2025. Any alternative recommendation on the motherboard?
I think i found somewhere (within hardware zone) posting that Gigabyte B650M Aorus Elite AX is a great alternative but the pricing will be a bit high. However, if the item can last longer i think the amount should be worth it. Cos my old build also uses Gigabytes which lasted me about 10 years. 😁
- MSI MPG A750GF
Thanks in advance.
abstrax
Thank you.
Well, its ur choice. Coz at 1st I saw ur post is getting a RTX 3070. Tats y i recommend a 4070. SLS selling $800++ now. Just went there today to get a PSU.
