Problem after install GTX780
LiquidX
Hello all ,
I have recently bought Asus GTX 780 DCII OC. My PC screen will go blank when gaming especially when GPU power load up to 86%. When i reduce the load to target 75% (using GPU tweak), the problem goes away, but at the expand of gaming performance. RMA my PSU seasonic X750 but problem still persist. I have done my research that x750 gold 80plus is enough to run my system unless i am wrong. I run stock. Tried clean install driver and also using different cable on different jack of PSU. Pls help me.
Spec
I7-4970
Memory-16Gb Gskill
1x SSD & 1 x raptor & 1x 7200rpm HDD
Asus GTX 780
1 loop water cooling (GFX and CPU)
4 x 200mm fan
1 x 140mm fan
1 x fan controller
Seasonic X 750
shadow84
Try increase volt by 0.012mv if you are gonna use 86% target load.
royfrosty
I doubt is the PSU issues.
Its more on your GPU.
Download Furmark Test. Run it. Monitor it for a while. See how it goes. Take note of the temperature graphs. Check also the GPU loading at the top right corner of the screen.
LiquidX
Yes same problem when loaded about 80% it restart my PC again. PSU / GFX problem?>
