Problem connecting to Singtel WIFI using iPhone XS Max
laucm
Any bro having problem connecting to connecting to Singtel WIFI using iPhone XS Max?
When I try to connect, it asked me for username and password.
No problem previously when I connect using my iPhone X. It just connect automatically.
Habrosus
No iPhone XS Max (yet) but if you've to do manual configuration, if I remember correctly...
There's an "EAP Method" drop-down list, choose the option "SIM". Thus, EAP Method = SIM. Then it should connect already.
Hope the above helps somewhat. Have done this with an Android as well as iPhone before.
RocketBunny
Download wireless sg app do the setup jiu ok liao
renfred89
arm there is no option to choose authentication method. the moment i tap on singtel wifi or SingTel wifi, it prompted me for user name and password. no other option available.
I believe the new iOS 12 has tweaked the user interface a bit.
I have reached out to singtel tech support just now, there were 3 actions done.
1) singtel reset my line totally, clearing singtel wifi records of my previous handset
2) advise me that should my next new iOS device giving me the same issue, to reset network settings via settings page.
3) to remove and re-insert the singtel sim card in the presence of singtel wifi coverage. (rationale is that singtel telco network profile will be reapplied and by default, iOS will turn on wifi and singtel wifi will automatically be registered, according to the agent).
I have yet to test out after my singtel wifi account got reset.
However, the above do not apply to android user, cos android can choose EAP SIM.
BoeingWong
Remove your SIM card,do a network setting reset,off your phone,put in the SIM card,start it.
It worked on me
IntelBen
i faced the same issue with you when i got the Iphone xs max.
2 things i have done in order for me to auto connect Singtel Wifi:
1. Perform network reset in you iphone.
2. Remove and insert the sim card.
You must perform both.
renfred89
call singtel to reset cannot arh?
laucm
Thanks to all for your replies.
Really need to do network reset?
Then need to re-enter all the saved wifi passwords again :s11:.....
magix
Yah that usually fixed the problem ( reset network)
laucm
Update:
At home, I took out the SIM card, soft reset, re-insert SIM.
Now at Jem: I am able to connect to Singtel WIFI. Yeah!
Didn't do any network reset.
Thanks to all bro for your advice!
memoriess
i did network reset and took out the sim card and put it in, still cant connect to wifi. any other solution?
renfred89
LIN_JOEL
btw is it possible to connect laptop to singtel wifi by keying the user ID and password?
tec_geek
I think if you have subscribed to a broadband subscription with Singtel, you can register for a Singtel Wi-Fi account.
https://www.singtel.com/personal/products-services/broadband/singtel-wifi
Under the “Singtel Broadband customers can enjoy Singtel WiFi!” section and click on “Activate Now”.
LIN_JOEL
renfred89
bro what do u mean by acknowledge the warning SIM card removed?
cos when you eject the sim when your phone is turned on, an error message will pop up saying sim card removed. you have to tap ok first in order to dismiss the message before you push back the tray in.
memoriess
Bro Renfred, my wireless@sgx profile wont affect my Singtel WiFi auto join right?
