trenzterra
- Sep 18, 2002
Hi all,
Was previously using a msi z77 mobo with i5-2400. I never ever use the sleep mode on my comp but yesterday I accidentally clicked sleep instead of shut down.
The computer became non responsive. When I press the power button to resume it boots up then shuts down again. After that, i had to reset the cmos before it could boot up again (even off and on power supply didn't work).
My mobo has been problematic the last few months due to a loose ram slot. So I thought it's time to finally upgrade my com so I bought a gigabyte Z170x-ud5 th with the i5-6600k.
However, I get similar symtoms. This time, when I try to use my keyboard and mouse to resume from standby, the computer becomes non responsive and behaves like it's shut down. I have to power cycle the power supply a few times before I can finally boot again. By the way, this whole time when it refuses to boot, the mobo is still receiving power from the power supply as the power led on the mobo itself is lit.
However, when I use the power button to resume from standby, it wakes up from sleep normally.
Any idea what could be wrong? At first I thought maybe my hd5850 was at fault, but even disabling it and using igp I still get the issue.
My remaining rig specs are on the right. Thanks!
