problem: start up issue
Rgyl11
Hi guys,
So whenever I start up my computer, there will be sounds (assuming it’s the fan) but no screen nor power light showing up in my pc. I’ll have to hold the power button and force shut down and turn it on again where sometimes it will start, sometimes same problem rises.
Another problem is when start up, there will be sounds and then it will auto shut down then start again hearing the teeet sound and screen shows and it works just fine.
May I know if this is normal or there is something faulty with my comp? :s11:
TIA
babyjyo
Hi guys,
TIA
Apart from the screen or powerlight, any other things that work or did not work after turning on? E.g disc drive, able to usb charge, any lights on the moherboard (if it has), any other parts that work or dont work?
Rgyl11
I didn't open up the case to do a proper check.. the monitor shows "Cable not connected" but i'm sure its not the monitor fault as there's no light in the front panel of the pc such as media control lights. How can I check if disc drive is working? I hear sounds coming from inside I believe its the fan.
And also after googling some of the other solved issues asking them to reseat their ram etc., as far as I know my Ram clips are super loose but the ram are still in position so Can't confirm if it is causing the problem
