Problem with my resolution?
marsbarsz
Hello all, I am facing some problems with the resolution of my 27 inch 1440p monitor as shown in the pictures below. I think the problem came about when I set "Change the size of text, apps and other items" to 125%, 100% is a little too tiny for me
As shown, my installers all face blurry texts.
Chrome:
Microsoft Edge
Texts on chrome were blur as compared to MS Edge.
I have (1) installed all drivers including the graphics card drivers, (2) configured ClearType texts but all to no avail.
Is there anyway i can still have clear texts with setting for "Change the size of text, apps and other items" to 125%? Thanks!
Elijahonli
then maybe you should have gotten a 1080p monitor instead of 1440p
dumboi2
This is a known problem. Try this:
lifehacker.com/fix-blurry-fonts-in-windows-10-with-this-utility-1734246822
marsbarsz
still doesnt work though, i plan to just reinstall my windows, can a windows key be used twice?
Elijahonli
no need to key in any key, just skip the key process. When setup is complete, it will auto activate. Nonetheless this is unlikely a software issue. Since it is fine on 100% and 125% is ok on edge.
HPpurchaser
Thanks
Need to give it a try anyway i guess, 100% is too tiny and 125% are too blur.
Did u turn on the clear text after u switch to 125 % ? that is a must
How can it be blur on a 1440p screen , i been using it long time no problem
