Problem with old comp - sometimes no response after power on
quarkz
Hi,
I have an old comp. Sometimes no response after power on, no beep sound at all. Then I check connection, take out/put back RAM, remove/install sata hdd connection. after power on, everything seems ok. use memcheck and no error reported.
So what is the likely problem with my comp? RAM, hdd, CPU or MB?
Thanks for the help.
Koenig168
There are a number of possible causes. The usual trouble-shooting involves reseating the RAM and GPU after cleaning the gold contacts and replacing the CMOS battery (if it hasn't been changed for a few years).
watzup_ken
No response as in no power, or power is on but no image on your monitor?
quarkz
Got power light on, but then nothing on screen and no beep sound.
jtjt00
TS, list down all parts of your old rig like those on the right -->
quarkz
How do I do that?
I will post this, easier:
jtjt00
Your rig is kinda old, don't what power supply this rig is using.
ZrE0_Cha0s
well if u have some spare parts try these:
test 1 by 1 the rams in each slots.
test the drive one by one.
test new and old psu.
test with your onboard gpu or discrete gpu.
