Problem with Predator G9-793
kchinbeng
Hi, I have been using this laptop for the past 3 years and recently just changed the motherboard from acer before the warranty over. But now I am having a problem playing borderlands 3 and it will lag and slow in loading. After plating a while it will appear memory error. If this is the case could it be my RAM is having issue? If so please recommend me a shop for this repair. Thanks in advance.
destiny88
theres no ram repair.... just buy new one and change. if not sure just go down sls find PC Dream check.
kchinbeng
I mean to check the laptop problem. If its ram then easy no need big bucks for repair. PC Dream reliable? Dun wish to kenna chop
