Problems with cpu
royalmage
Hey guys thanks for looking, heres a few of the problems im facing currently.
firstly i think my cpu has a circuit loose somewhere because i get electrocuted whenever i touch my usb cables or my pc itself (places that has conductivity like back of cpu and some parts of side panels)..
secondly i am unable to update my gpu drivers as i will get bsod everytime i try to update to any version.
lastly is i get random bsods(this is bad news).
hope you guys can tell me whats wrong and ill try to fix it
thanks
all these happened after i went holiday 1 week.. previously cpu was running fine
fleas1
thanks
Have you tried going into safe mode and uninstalling your gfx drivers?
jtjt00
Check the power cord connecting to the power supply, grounding issue.
royalmage
omg bsod getting quite frequent now
heres the message
havetobuy
your gfx card run current..if u touched the vga port u wud feel short electrocuted
gfx card internal goin up lorry soon & show symtoms of not updatin driver bios
royalmage
how u know is from gfx??
i touch my usb cables also will kena sia.. anywhere the cpu that conducts electricity basically will kena electrocuted also..
but i think my gpu gonna up lorry soon.. sian
royfrosty
It seems more like bad grounding of the chassis.
Check the PSU by pulling it out from the chassis and leave it outside and try power on.
Try touching wherever you think that there is shocks. If it doesnt shock like it used to be it is possible that the PSU has poor grounding.
