Hi, thanks! Feel more confident about it now. Folks in here seems to have really deep pocket...really really deep pocket. Mine is just a humble one.
There's wedding and renovation to think about. So ya...
Will update on my appointment with JP next week. Anyone else in here who has gone to JP with my sorta budget? Care to share?
My budget was a humble 3k and managed to get their Solasfera diamond
If you have set a budget, then you should stick to it. You can adjust the other diamond factors like clarity and color to fit your price. But never sacrifice on the Cut!![]()
How much more is a JP Solasfera cut compared to a round brilliant? Whats a good estimate of a 0.7carat F/G VS2 super ideal round cut?
How much will a 0.5carat cost at JP?
sure you can get one from JP. cos i got mine from them.
1 more week before collection ^_^
hi what are the payment terms? Deposit and then payment on collection? Or is it full payment upfront?
hi sorry.
these are the link.
0.78-Carat Heart Shaped Diamond | Blue Nile
0.80-Carat Heart Shaped Diamond | Blue Nile
appreciate your feedback and advise.
The first one has strong fluorescence which is a big no no.. The symmetry is only Good. I'll pass on this one
The second one Table % is slightly too small. It'll make the diamond look smaller. You are also paying a high price for the IF clarity..
The third one also a Table % that is slightly too small. The rest seems fine except for the ratio. Try to get a ratio closer to 1. This one has a ratio of 0.84, which makes the diamond looking wider than normal.
can i know Table % should be in which range consider acceptable or high end range.
thank you.
Hi everyone,
Seek ur advice between the two super ideal stones from jannpaul on which is better?
1) 0.715, E-VS2 @ $6,500
2) 0.75, D-VS1 @ $8,000
Thank you so much!
