EricMagnusLensherr
- Dec 17, 2004
thanks hollander! yah the diamond alone is $2900 so with settings will set me back arnd $3450. u think the price is reasonable?
Solasfera is a branded modified round cut and price controlled by a single supplier. Since its price controlled, if you like the look, get it, since you will not be finding it at much different prices anywhere else(and JP is the only authorized seller in Singapore and Solasfera is pretty strict about this stuff), other wise, you can consider a normal round brilliant.
My best advise would be to get the price of a normal round brilliant with similar or close specs and see if you are willing to pay the price difference for the brand/modified cut/solasfera look.
