Eugene_Hunk
- May 21, 2012
Guys. Can u tell how good it this diamond? Gia 2161800057.
Thanks
HCA score is 0.8 which is a good indicator. Did you see the diamond with the scopes?
Thanks
Here is the design of my ring. Any comments?
Nice!! Are the side diamonds octogon too?
Visited JP over the weekend with the gf to just find out what are the options available. Shown a few diamonds ranging from .4-.6, all super ideal.
.41 G VS2 was just under $3k
.53 G VS2 $3950
.56 G VS2 $4250
.606 G VS2 $4950
I need to take a look at H colour before deciding if it's worth it to drop colour and go for bigger carat instead. Sadly JP does not carry H and below.
Haha.. nope.. they are round.. I ask them the same thing too and they say there is no so small octagon..
For me, I would prefer a F as I want my diamond to be within the colorless range.
Saw H before in other shop and I can see some yellowish in it.
when will your ring be ready? I was told that mine will be 6-8 weeks.![]()
Guys.. aset and hearts/arrows scope is different right? Some shops tell me its the same thing.
guys, i got the scope image but dont know how to post it.. haha
can anyone tell me how to post?
Whichever shop tell you that makes it easier. Just walk away only.
Both are completely different la.
ASET scope is to see the light performance and check light leakages.
Hearts and arrows scope is to check the crown and pavilion symmetry only.
You need to see with both.
This is why you die die must use the Aset scope
Can use tinypic dot com
Can guestimate for me how much would a 0.8ct cost without setting, compared to a 1ct?
Thank you!!
