PSU click sound.
pinky867
There is a single click sound when I press 'start' and also when the system shut down. My former CX430 and other OEM system don't have this sound.
Is it normal?
Please advise.
Thank you.
ZawLee
Double check if it's the click from hdd or psu. I remember there are ckicks from hdd when it gets powered up.
ZawLee
If it's from psu and it gave a click sound, prepare for rma. It is dangerous to use it again.
If it's from hdd, rather a click, it's more of a tick. Normal. Because it is writing and reading.
KeYoKe
u sure? :s22: have used the following PSU with the click sound: superflower golden king, seasonic P660, Superflower HX600
it is the relay sound like what roy mentioned
ZawLee
When you first turn on or power up the PC it should have a relay sound that sounds like a click.
And when it turns off completely it should have a click also.
Zzzz some people will never explain their troubles properly.
